2016 Silverado 2500 HD Brake shoe / emergency brake
Old Jun 27, 2023 | 9:38 AM
JavDawg69's Avatar
Default 2016 Silverado 2500 HD Brake shoe / emergency brake
Greetings all - I have a 2016 Silverado 2500 HD. Replacing the passenger side brake shoes/emergency brake. For some reason the new rotor will not go over the new shoes. The adjustment wheel is in all the way, parts all appear to be the same. Can anyone recommend any ideas or thoughts?
Thanks
J
Old Jul 5, 2023 | 7:18 AM
Gumby22's Avatar
If you’re still needing an answer…
Oftentimes the shoes can be off center relative to the hub, so you just need to start the rotor onto the hub, then work the shoes back and forth or up and down to line them up with the rotor.
If that doesn’t work, it’s possible the cable isn’t fully released. Disconnect the cable from the actuator lever and see if the rotor clears the shoes.
Old Jul 5, 2023 | 8:49 AM
JavDawg69's Avatar
Thanks!
KTR
Mar 1, 2023 2:18 AM
sjlewis
Jun 17, 2011 11:37 PM
01Vette
Sep 17, 2008 9:38 PM
Phil Speadahead
Mar 26, 2008 9:07 PM
