Battery replacement 2014 Silverado
Old Nov 13, 2020 | 4:09 AM
15002014's Avatar
Default Battery replacement 2014 Silverado
Are there specific steps to follow when replacing the battery of a 2014 Silverado?
What I found in the manual is that the driver power window will need to be reprogrammed for the express-up feature to work.
I remember one of my cars had to be reset by a technician, because it lost its programming and would not even start.
Alex
Old Nov 13, 2020 | 7:39 AM
I have a 2013 Silverado and have replaced 2 batteries without having to do anything. It started right up and everything worked.
Old Nov 14, 2020 | 11:38 AM
+1 what he said
disconnect the negative terminal first. on install connect the negative terminal last. if it has a battery blanket transfer it to the new battery...protects the battery from underhood heat. Always make sure the the battery hold down is secure. Do not drive without a properly secured battery.
express down relearn can be done yourself without any special equipment.
JDHIGHFILL
Jul 6, 2018 10:12 PM
RickInKy
Oct 17, 2016 8:19 AM
dgriffith
Mar 11, 2015 12:46 PM
whitesnowden
Oct 25, 2014 2:24 AM
rubydsouza
Jul 29, 2014 6:24 AM
