Hey guys, I was in the process of changing my fuel pump assembly when I broke a plastic Y type join between some fuel lines. I'm not even entirely sure what the third leg of the Y feeds as its not on the exploded diagram for the fuel tank, so maybe someone can chime in. I believe the fuel line is nylon, but I have no idea how to repair this joint. Photos are attached for clarification.
Broken Y connection Fuel lines. Mystery part is the thing on the right.
Welcome from Florida. You can buy plastic or brass Y or T fittings to replace your broken one. All you need to know is the hose size. Just make sure they are fuel rated.
I measured the inner diameter and I think it is 3/8". I am having a hell of a time getting the ****** fitting out of the hose though. I was trying to avoid buying hose and making new lines
