Error MSG Reduced Power to Engine
Old Jul 17, 2018 | 8:08 AM
jwhite58502's Avatar
Default Error MSG Reduced Power to Engine
2014 2500 Silverado 6.0 liter, had 5th wheel plate put in last Wednesday, drove it home parked it would not start Saturday morning got error msg once that said reduced Engine Power, no crank no sound no clicks nothing. Checked all fuses under hood and cab all good. (thought maybe electrical because of 5th wheel). Battery fully charged, tried jumping it even with full battery and NOTHING when turn key. Research says reduced power may be throttle or transmission when moving but can't even get it to turn over.
Old Jul 17, 2018 | 2:01 PM
deer2018's Avatar
same problem with 2014 LTz71 came home parked went inside house came back out and truck will not start nothing turn key nothing new battery installed same problem will not start after you park it for a few minute take about 15min then fires up
Old Jul 17, 2018 | 2:03 PM
deer2018's Avatar
i heard several issue from bad starter flagger in muffler and anti-theft need upgraded
Old Jul 17, 2018 | 2:08 PM
So here is the Diagnosis bad ECM needs replacing to the tune of 728.14 That includes tow. Further in this forum about page 3 someone else got the Reduced Engine Power mgs and it was their ECM/ECU as well. I hate computers
