Front tires wearing badly on outside
Old Aug 1, 2018 | 3:33 PM
rockfarmer's Avatar
Default Front tires wearing badly on outside
I took my truck (Silverado 3500 DRW) in today to have the tires rotated and balanced. Both front tires were worn badly on the outside. The technician said that because I pull a 38ft 5th wheel trailer, the front tires are prone to do that. But we never had a problem with 2 previous trucks wearing the front tires abnormally. Has anyone else experienced this problem? Seems kind of funny to me. I am wondering if it is an alignment problem instead.
Old Aug 1, 2018 | 5:02 PM
I would have the alignment checked before I did anything else.
Old Aug 1, 2018 | 7:48 PM
if the tires have toe wear..its possible...post a pic of the tire wear.
you have independent front suspension....whenever the ride height changes...the toe setting can change. So if the load on the truck is heavy enough to change the ride height...its possible but for a 3500 it would take a lot of cargo weight. What is the tonque weight? I would check the fender heights before and after connecting your trailer...is there much change?
Its also possible the toe setting is just set wrong...have the alignment checked as old chevy posted. Make sure the truck is loaded as it would be for the majority of its driving.
