Hydro locked Engine
Old Nov 23, 2017 | 2:02 PM
ChromeGear's Avatar
Default Hydro locked Engine
I recently bought a 2016 Silverado, and it seems that the engine is hydrolocked I already removed the spark plugs to turn it over and get whatever water was in out. I also flushed the system and after all that I put the plugs back and started it. It seemed to have worked for a second until it stalled and turned off again. I forgot to check the intake and it turns out there was water in there too, but I can’t turn the engine any more. It does not give one way or the other what could be wrong?
Old Nov 23, 2017 | 2:33 PM
kevinkpk's Avatar
It might be the fact it dosen't like to swim? You'll need to give more information on this.
Old Nov 23, 2017 | 3:56 PM
ChromeGear's Avatar
What exactly would you need to know, I’ll try and give as much as I can.
Old Nov 23, 2017 | 4:05 PM
kevinkpk's Avatar
Ok, what happened to it that flooded the engine with water. That's for a start
Old Nov 24, 2017 | 7:09 AM
Did you drain the oil pan? Did you check the transmission for water?
