Outside Temp Gauge
Old May 24, 2020 | 5:00 PM
jim larson's Avatar
Default Outside Temp Gauge
Temp gauge not working. Says 64 and its 82. Whats wrong? How do you fix? 2017 silverado 1500 crew cab Help!!
Thanks, Jim
Old May 24, 2020 | 8:09 PM
Little Bear's Avatar
It is either the sensor located center behind the grill, or the display. in this case I would think the sensor as the displays typically just go out or read out garbage.
Old May 25, 2020 | 6:59 AM
jim larson's Avatar
Thanks, I have seen a video on changing the sensor. Looks like a real pain. Is there any way without removing the panels and grill?
Old May 25, 2020 | 8:14 AM
I think that is the only way to get to it.
Old May 25, 2020 | 10:57 AM
do you have a grille insert...anything that blocks or changes air flow to the sensor will skew the sensor reading. any resistance changes in the wiring/bad connections will cause inaccurate readings.
is the gauge off all the time or some of the time. the gauge reading is not a live reading. it updates from a set criteria so it will be off until it updates.
Old Feb 2, 2021 | 6:56 PM
texrex's Avatar
My 15 did the same , I changed it out . Have to remove the grill , sensor is not expensive .
john2000
Apr 26, 2020 12:41 PM
Sonicd
May 13, 2013 2:48 PM
2001astrovan
Astro
May 25, 2010 7:07 AM
hemconst
Dec 12, 2007 12:14 AM
