19 RST rubbing noise
Old Dec 7, 2020 | 6:19 PM
Mobud's Avatar
Default 19 RST rubbing noise
Anyone else have a rubbing noise, sounds like a dying seal coming from rear end, usually if truck sits for some time(over night or during day at work). Usually happens when I first take off from a stop then goes away and will continue after each stop until I drove for a bit. I know others are having this issue on other forums but wondering if anyone has found a solution
Old Jan 6, 2021 | 10:24 PM
TheGriz's Avatar
My 2019 LT Z71 has a similar noise but, mine seems to come from the right front. I have been contributing it to a slight brake pad rub. It goes away after 3 or 4 rotations of the tire. It's also developed a squeal from the same wheel when applying the brakes while going backwards.
rervf23
Aug 14, 2011 11:30 AM
bsoxbito
Oct 9, 2010 5:02 PM
TRProffitt
Jan 10, 2009 9:16 PM
jmjhd
Jan 12, 2008 1:34 PM
02TrailBlazer
Mar 14, 2006 2:28 AM
