2019 Silverado Z71-RST ECM Pinout
Old Apr 27, 2026 | 11:47 AM
DJ2019Z71's Avatar
Default 2019 Silverado Z71-RST ECM Pinout
Can anyone assit with the ECM pinout for the EVAP Vent Solenoid control wire? I'm fighting a P0498 code and have replacee the solenoid and electrical connector and now suspect a wiring issue between the solenoid and the ECM. I located the ECM behind the wheel skirt at the drivers side front wheel. there are 3 large X-connectors, 2 black and the bottom one is blue. Need to idnetify the correct X-connector and pin number for the wire to the solenoid (negative pull-down wire). thanks!
Old Apr 27, 2026 | 7:09 PM
chem_man's Avatar
15 Year Member
Go to https://lemon-manuals.la/
They will have a service manual with electrical schematics for most if not all of your needs.
Good Luck!
couchmusician
May 19, 2020 4:30 PM
kenurb
Avalanche
May 7, 2019 4:15 PM
Paulie710
May 15, 2018 8:19 PM
jameslbeach
Jan 20, 2012 2:03 PM
Stacy.aap
Jun 12, 2011 8:28 PM
