2020 LT Trail Boss 5.3 Ongoing Misfire
Old Mar 11, 2021 | 1:01 AM
HunterD's Avatar
Angry 2020 LT Trail Boss 5.3 Ongoing Misfire
Hey everyone, I have a 2020 LT Trail Boss with the 5.3 in it. I got it December 2019 and have loved every bit of it, however around 17k miles it had a misfire CEL. The dealer took it in for almost 3 weeks and finally fixed it. It had another blinking CEL a few months later, went to the dealer again, a misfire but this time they cleaned an injector and added conductive fluid/lube on the connector prongs to "help it". I've been feeling it misfire since but the CEL doesn't come on for it, I brought it back to the dealer a 3rd time and they told me they'd have to charge me diag time to look at it. Mind you I'm at 29k miles when I asked them... It still does it from time to time and I'm at 31k miles currently, what do I do? Does anyone else have this issue? Thank you.
Old Mar 12, 2021 | 5:27 PM
oilcanhenry's Avatar
What are your OBD II codes?
Old Apr 19, 2021 | 3:39 PM
jamesp's Avatar
Friend of mine had a misfire problem. Dealer brought in someone from GM and it turned out to be a bent push rod. Truck had less than 10,000 miles on it.
Old Apr 21, 2021 | 4:34 AM
Glad to hear it. Pushrods don't normally bend unless you have a condition they didn't address.
Old May 4, 2021 | 6:51 PM
Coja's Avatar
the bent push rod was probably due to a collapsed lifter, i have seen several come through our shop with with that issue. GM has released a bulletin about it #PIP5776C. Of the 8 that have come through the dealer im at all 8 had bent (intake) push rods with the root cause of failure being a collapsed (exhaust) lifter. and only one of those had a damaged camshaft. Usually if its the lifter you have some type of noise along with the misfire, typically a loud pop at cold start up. not always though
Gilly47
2014 - 2018 (GMT-K2)
Mar 25, 2021 2:29 AM
Tony Tiller
2007 - 2013 (GMT900)
Dec 14, 2020 12:06 PM
Davidsednothing
Dec 6, 2014 9:23 PM
one8thursize
Sep 23, 2012 1:33 PM
