Fog Light LED Replacement?
Old Dec 15, 2022 | 9:19 AM
Alan D Learned's Avatar
Default Fog Light LED Replacement?
Hello everyone. My question today is can the white OEM fog lamp LED bulb be physically exchanged with a yellow LED bulb without replacing the entire light assembly? Or should I use some sort of yellow-colored vinyl film to cover the lenses? Thanx!
Old Dec 15, 2022 | 8:22 PM
chem_man's Avatar
15 Year Member
It is more than just putting a yellow tinted piece of plastic between the bulb and the front lens. One must take into account the light pattern that is given off from the LED vs the incandescent bulbs, AND the geometry of the reflector. The original reflector was designed with an incandescent bulb in mind. Because most LED bulbs have a vastly different light pattern, the amount of light delivered will be much less.
Old Dec 16, 2022 | 2:04 PM
Thanx for the science lesson but you didn't answer my question. . .
Old Dec 20, 2022 | 4:56 PM
chem_man's Avatar
15 Year Member
Sorry, I misread your original post. As long as the bulbs are the same number (e.g. similar to 3057 vs 3057A), it should work.
phness
Corvette
Feb 14, 2018 11:40 PM
lost50
Avalanche
Dec 11, 2012 6:48 PM
chevyman890
Mar 12, 2011 1:08 AM
AlaskaJeff
Oct 13, 2010 10:18 AM
tahoeguy98
Dec 29, 2006 4:47 PM
