The ultimate LED upgrade option Custom for your Silverado | Pro-CS-01L
Platinum Sponsor
Location: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
![](https://cimg1.ibsrv.net/gimg/chevroletforum.com-vbulletin/1903x903/1_1dc1a085aed5d18ca13f89ce01db60b5dd113e64.png)
For Silverado owners, upgrading to LED bulbs is not a hassle-free affair. The Silverado's headlight housing has an off-center design, which causes universal LED bulbs on the market to be unable to install properly because the heat sink hits against the edge bracket of the housing.
Customization is the best solution. Therefore, Lasfit has undertaken industry responsibility. We listened to Silverado owners' feedback for targeted development, finally polished two bulb types, and what is ultimately presented to customers is the Pro-CS-01L.
- Fit for the 2019-2021 Silverado 1500 low beam. https://www.lasfit.com/products/2019...1-w-dust-cover
- Fit for the 2022-2024 Silverado 1500 low beam and high beam. https://www.lasfit.com/products/2022...-fit-led-bulbs
- Fit For 2020-2024 Silverado HD 2500/3500 low beam and high beam. https://www.lasfit.com/products/chev...-h11-led-bulbs
![](https://cimg8.ibsrv.net/gimg/chevroletforum.com-vbulletin/1600x1600/2_6a19e71bc4ed7052bf5755ecd81ef5e448790792.png)
New Features of Pro-CS-01L
Custom Design: High Brightness with Optimal Beam Pattern
The Pro-CS-01L series LED bulbs have a true power of 50W and 5000 lumens per bulb, with high brightness, providing clear vision for safe driving. Besides, it features 80*80MIL high lumen LED chips and an accurate mount socket design, ensuring the optimized beam pattern with a clear cut-off.
The LED chip and the base socket is set at the best angle to get the best light beam pattern. When you can install it securely to lock the bulb in the housing, its beam pattern is perfect without needing further adjustment. We have test many times until the output beam pattern is most close to the halogens.
![](https://cimg5.ibsrv.net/gimg/chevroletforum.com-vbulletin/1024x1024/3_29683bce05d5f347baf4f7cf35e968d3c2b33077.png)
Multiple Cooling System: Strong Stability
Dual-ball-bearing fan is at the bottom of the LED bulb. We maximized the dual-ball-bearing fan according to the OEM housing space. 9000RPM 40MM dual-ball-bearing with 7pcs fan blades offers the maximum heat dissipation surface. The larger the surface area the cooler the LED bulb will remain.
Built-in turbofan and a vent on the dust cover is another cooling system. The turbofan can dissipate heat to outside from the housing through the vents. This dual-cooling system keeps the brightness steady, no longer worry about the LED bulbs will overheat when they are running.
The excellent cooling system ensures that the bulb does not overheat and shut off when running at ultra high power. High luminosity products must face the challenge of stability in operation, and clearly, we have successfully solved the issue of the bulbs shutting off.
![](https://cimg7.ibsrv.net/gimg/chevroletforum.com-vbulletin/1024x1024/4_fb870a9c9b8c6f170f8d770fdfa2b62fd939b1eb.png)
OEM-design extended Dust Cover
When the heat-sink returns to the center of the housing, the original dust cover is most likely unable to be installed. In the past when encountering such solutions, car owners usually had to painfully abandon the dust cover or drill holes in the dust cover for the heat-sink to pass through.
However, for Pro-CS-01L we have customized an extended dust cover. The extended dust over was made based on the OEM rubber dust cover. It not only perfectly protects the LED bulbs from water/dust/moisture/other messes, but the extension design also provides a bigger space for the best heat-dissipation effect.
The dust cover also integrates the external driver, which is completely different from the traditional built-in driver design. LED bulbs with built-in drivers are usually made smaller for higher integration, which certainly compromises heat dissipation space. While enlarging the fan system, the Pro-CS-01L series places the driver inside the dust cover, again expanding the heat dissipation space and ensuring thermal performance. The addition of the extended dust cover design gave this product more possibilities.
![](https://cimg5.ibsrv.net/gimg/chevroletforum.com-vbulletin/1600x1600/5_42f851a3a8a461cb7c8a0ed4a42df03f7c4dac4e.png)
If you’re looking for an easy upgrade for your Silverado with halogen assembly, LASFIT Pro Option will provide an instant performance boost, modern style, and an unbeatable bright output. It will be your best aftermarket choice.
Little Jimmy
11
April 2nd, 2023 7:51 AM
