I have replaced the plugs, cap, rotor, map and pump and it runs rich And will not stay running when it does start. have to floor it sometimes to get to start. what is wrong with it?
Gasoline probably gummed up something in the TBI after all those years,
it was the fuel press reg. but now must keep floored to start and then dies...maybe tps or iac?? also oil up through valve cover on drv sd. egr cleaned on pas sd. just started this...help plzzz….
