Astro 1985-2005
Platform: M-Body
1997 astro van changing spark plugs
Old Nov 21, 2008 | 10:15 AM
alka's Avatar
Default 1997 astro van changing spark plugs
Hi,
Is there a better way/trick to approach the Spark Plugs / Once you open the do house these Plugs are far down to get access from the top /inside the van, wondering what is best way to approach these all plugs / right tools to take these out without breaking any ceramic caps etc.
You have pictures that will help !!!!
Thanks in advance,
Alka
Old Dec 9, 2008 | 6:23 AM
bdblly's Avatar
Default RE: 1997 astro van changing spark plugs
The 88 I used to own (V-6) I was able to change all plugs from the top except 1, and I don't remember which one it was, but it came out from underneath. My 92 V-8, all plugs were changed from top.
Old May 14, 2018 | 12:39 AM
Don Ward's Avatar
I changed my plugs on my 97 astro today . it took 45 mins. Heres what u do jack it up put it on jack stands , remove the tires , facing the inner well you will see 2 flaps that separate the tire from motor , The plastic retainers pop right out . once those are removed , you can see all the plugs . I used 2 8 extensions , 1 with a wobbly tip . A long pair of needle nose helps getting the plug wires off . Good luck
Old May 14, 2018 | 11:48 AM
Go to YouTube.com and look for a video that shows how to do it.
Old May 15, 2018 | 12:31 AM
Don Ward's Avatar
Why should I go to utube . I believe the way I did it was fine
Old May 15, 2018 | 7:55 AM
I was referring to alka.
Old May 15, 2018 | 10:40 PM
Don Ward's Avatar
Sorry , Im new at this .
Old Jan 26, 2020 | 4:41 AM
delshan's Avatar
Jack the car up, remove front wheel & access panel behind it, should be easy then.
Old Jan 26, 2020 | 2:44 PM
@delshan
which Don already said in 2018
2004CMM
Jul 21, 2010 6:39 PM
ddls1
Jun 25, 2010 6:09 AM
06uplander
Uplander
Jun 2, 2010 7:33 AM
Lees2500HD
Jun 29, 2008 6:04 PM
epekarik
Jul 14, 2006 12:51 AM
