Astro 1985-2005
Platform: M-Body
2000 Astro Van stalling problem...need advice please
Old Oct 3, 2017 | 4:47 PM
porkeythepig's Avatar
Default 2000 Astro Van stalling problem...need advice please
I have an intermittent stalling problem in Park when the temperature reaches normal.
It always starts right back up
Took it to Mechanic...He says Fuel Filter needs changing.
Talked to 2 other Mechanics...Both said Do Not Change Fuel Filter because it will cause the Fuel Pump to Fail because the pressure will increase if the fuel filter is changed.
Advice needed
Don't know what to do !
Thank You
Update:
Computer is showing Code for O2 Sensor and Code for Torque converter Clutch solenoid
HELP !
TY
