Astro 1985-2005
Platform: M-Body
2002 Astro AWD brake bleed problem
Old Oct 3, 2018 | 10:14 AM
tommysastro's Avatar
Newly Registered
Default 2002 Astro AWD brake bleed problem
After replacing front pads and rotors, and replacing bleeder screws, I cannot seem to get brake fluid to bleed. Reservoir is full. Any suggestions?
Old Oct 3, 2018 | 11:16 AM
Did the master cylinder run out of fluid? If so you will need to bleed the cylinder first.
Old Oct 3, 2018 | 10:55 PM
oilcanhenry's Avatar
Why did you replace the bleeders? No matter, you are going to be bleeding the brake fluid out until it has no air. You can pressure bleed it or gravity bleed it.
