Astro 1985-2005
Platform: M-Body
Gas Cap Stuck
Old Mar 5, 2020 | 8:15 AM
dobaroy's Avatar
Default Gas Cap Stuck
On our 99 Astro we are on our third gas cap and each one of them gets stuck and is very difficult to remove and the same to get it back on. Has anyone had this problem or any suggestions. By the way when we first get the gas cap it works fine for about 2-3 fill ups, then it starts acting up. Thanks.
Old Mar 5, 2020 | 10:48 AM
Are all the caps you tried the same brand?
Old Mar 5, 2020 | 4:16 PM
dobaroy's Avatar
Thanks for the reply. No the caps were different brands, one was a Stant, the latest one was a Napa brand. Any other ideas?
Old Mar 6, 2020 | 7:19 AM
Is the pipe end the gas cap screws onto damaged in any way? After the gas cap gets stuck and you finally remove it, is there any damage to it that was caused by the gas pipe?
Old Mar 6, 2020 | 2:04 PM
dobaroy's Avatar
Thanks, will have a look at that tomorrow and see if there is damage.
Old Mar 6, 2020 | 10:48 PM
+1
no mention of a pressure release when the cap is removed so the only parts involved are the cap and filler neck.
Old Mar 9, 2020 | 7:29 AM
dobaroy's Avatar
Checked cap and filler neck thread, looks OK. Tried something different . . . If you remove the gas cap before you run the vehicle, it works fine, seems to be pressure building up after you run the van and then the cap is difficult to remove.
Old Mar 9, 2020 | 11:41 AM
any problems with slow refueling? if yes, is the check engine light on? if yes, post the codes.
Old Mar 9, 2020 | 3:21 PM
dobaroy's Avatar
Thanks tech2, no problem with slow refuelling, no check engine light. Any other ideas would be appreciated.
Old Mar 9, 2020 | 6:27 PM
Pressure shouldn't be building up. The venting system isn't working right.
