Astro 1985-2005
Platform: M-Body
Headlight switch problem
Old Feb 8, 2007 | 9:11 PM
flynnstone_45's Avatar
Default Headlight switch problem
I have had alot of trouble lately with my headlight switch. I came home from college and charged my cell phone in the cigarette lighter. Tryed the headlight switch the next day and it would kill the van. So I replaced the headlight switch...not any better. Looked behind the battery and found that a piece of the wiring harnes was damaged, replaced that still no better. I tried to by pass the wire and found its not in the red wire form the switch to the power source behind the battery. I am almost 100% shure that it is killing the fuel pump when the switch comes on. It also resets the radio. The 20amp fuses which i think the wire to the headlight switch is were blackened one side so i replaced those and it still continued with the same problem. Does anyone have any idea what the deal is?? Thank you for you time.
Old Feb 9, 2007 | 12:21 AM
golfer's Avatar
Default RE: Headlight switch problem
Are there any modifications to the lights... trailer harness , fog lamps ??
Old Feb 9, 2007 | 1:29 AM
I haven't modified the lights in any way. I use the fog lights that came standard on the van.
Old Feb 9, 2007 | 11:13 AM
golfer's Avatar
ORIGINAL: flynnstone_45
What happens when the light switch is turned on and the van is not running ?
Do the dash lights go ut as well ?
You say it resets the radio memory will it shut off the radio ?
So far it's sounding like a loss of battery power. If you haven't done so yet... clean the battery cable and battery terminal connections throughly to start.
Another thing is how good is the battery ?
Old Feb 9, 2007 | 2:31 PM
when the van is on and then i turn the switch on it dies. the dash lights as well go out, the radio shuts off and resets the time. I'll take a wire brush to those cables today, but the look clean-no corrosion. the Batter was replaced in October of 2005 so its not that old. I just can understand why fliping a switch kills the whole vehicle. thanks for you time guys it very much appreciated
Old Feb 10, 2007 | 10:46 AM
golfer's Avatar
Try turning on the wipers , radio , heater and anything else at onceother than the lights to see it does the same thing.
garyv990
Feb 11, 2015 9:52 PM
droppedmybeerdamnit
Nov 24, 2011 8:43 PM
leejosepho
Oct 26, 2009 10:51 PM
warlok
K5 Blazer
Apr 27, 2008 7:46 PM
RTillery
Jan 6, 2007 12:18 PM
