Astro 1985-2005
Platform: M-Body
injector pulse issues
Old Aug 13, 2019 | 2:47 PM
boogiewmf's Avatar
Default injector pulse issues
02 Astro RWD. Weak injector pulse. When you turn the motor by hand the injectors will fire. When you use the starter the noid light is really dim. Have replaced the PCM, ICM, Crank sensor, Cam sensor, ignition switch, ran jumper wires to eliminate harness issues checked all the harness grounds and grounded the engine to the chassis with another ground. Any help would be greatly appreciated.
Old Aug 16, 2019 | 10:35 AM
boogiewmf's Avatar
Solved. Third time thru the data stream MAP showed unusual voltage in the MAP replaced started right up.
PMC45
Dec 7, 2017 9:25 AM
nauticstar87
Jul 1, 2016 2:05 PM
rynmcdonald
Nov 19, 2014 1:53 PM
jtak101
Jan 5, 2014 2:41 PM
Fletch359
Jan 6, 2011 6:14 PM
