Astro 1985-2005
Platform: M-Body
Nobody can figure it out???
Old Aug 17, 2022 | 9:41 PM
jerryjerry05's Avatar
Default Nobody can figure it out???
1999 Astro 230K
Nobody can figure it out why it runs so bad.
Starts and idles ok, then as it warms it acts like it's running on water mixed in the fuel.
Cuts in and out.
Not sure it's losing spark??
Good coil, all kinds of new sensors, new plugs, wire , cap, rotor, new filter, no water in the gas.
The question?? If I decided to get another older style distributor with the built in coil would that work or would the computer be a problem?
The throttle body would that work with a regular old style dist?
Would it work? what problems would I run into?
Thanks, Jerry
Old Aug 17, 2022 | 10:30 PM
kevinkpk's Avatar
Originally Posted by jerryjerry05
1999 Astro 230K
Cuts in and out.
Thanks, Jerry
Inspect all vacuum hose's, and air intake system for split's etc.
Old Aug 18, 2022 | 6:00 AM
GWD's Avatar
GWD
Check distributor gear for wear. Replace gear or get new distributor. A defective quality metal was used over the years.
Old Aug 18, 2022 | 11:57 AM
M.E.V.'s Avatar
Check your fuel filter.
RickR90s
Aug 10, 2018 8:47 PM
abates2k
Astro
39
Jan 21, 2015 1:29 PM
Clay 78 C-10
Feb 2, 2012 10:23 PM
bamadog9
Mar 5, 2008 7:25 PM
Soulcrusher
Jan 24, 2006 10:17 PM
