Astro 1985-2005
Platform: M-Body
Servicing the AWD? Is this something a DIYer can do?
Old Sep 11, 2018 | 7:18 PM
illbfrank's Avatar
Newly Registered
Default Servicing the AWD? Is this something a DIYer can do?
Just wondering how to go about servicing the AWD in my 2000 Astro.
Old Sep 12, 2018 | 3:48 AM
oilcanhenry's Avatar
Sure you can. You'll need to crawl under the vehicle and pull the fill and drain plugs drain into a container. Then you refill it to the bottom of the fill hole. GM calls for ATF III fluid for the Astro AWD, but you could use Dex 4 or 6 or a "synchomesh" type manual transmission fluid IMO.
