Chevrolet Avalanche
Platform: GMT 805 & 900
07 Nav Upgrade install issues
Old Apr 16, 2007 | 9:54 AM
jazzson007's Avatar
Default 07 Nav Upgrade install issues
Sup everyone. I'm new to this so bare with me. I purchased a black 07 Avalanche LS without Bose and Navigation. I upgraded my stock radio for the nav unit #15882767. I purchased the unit on Ebay for $750.00 Brand New and it works great but after the install my speakers are playing very low. When I raise the volume, it only goes to a certain volume. The dealer installed it and flashed the unit twice but there's no difference. The dealer said that he's gonna check with GM to see if I can get a Bose Amp and get back with me. Does anyone have this issue when upgrading their stock radio. Can I just get another amp in replace of the factory amp to amplify my volume and also my OnStar voice promp is very low, is this all a part of the same issue?Anyone please help......
Old Apr 16, 2007 | 9:19 PM
omiz07slab's Avatar
Default RE: 07 Nav Upgrade install issues
the navi unit is ment for bose speakers... the navi unit puts out either a high signal or a low signal to the speakers... meaning you will have to bypass the factory amp... or get a special wiring harness...im not sure if you understand what im saying... if not message back and ill explain more...
Old Apr 16, 2007 | 10:57 PM
jazzson007's Avatar
Ok. I understand about the amp but what's the wiring harness and which do you prefer? Everything works except for that.
Old Apr 16, 2007 | 11:18 PM
omiz07slab's Avatar
I am unsure about what you will need....heres a link http://www.jpcustoms.com/store/customer/home.php?cat=307to a company who sells GM parts and has experience with what problems you are having... i would try giving them a call and telling them your problem...those are some of the AMP interfaces or wiring harness... i dont see one for adding a navi to a non-bose system... also when i had my 2004 Tahoe and wanted to retain the Bose-Speaker system but add a new head unit, the audio shop that i had all my work done at was able to by-pass the factory amp to work with an aftermarket stereo... something simillar may have to be done for your system to work...
Old Apr 16, 2007 | 11:29 PM
jazzson007's Avatar
Good looking out
Old Apr 16, 2007 | 11:32 PM
omiz07slab's Avatar
No problem... let me know how it goes... i have a 2007 LT avalanche w/bose but no navi and want to upgrade sooner or later...
Old Apr 27, 2007 | 4:23 AM
gm_geek's Avatar
ORIGINAL: jazzson007
all You have to do, is to buy and install any aftermarket 4 channel amplifier and buynon XMIPOD harness from American international ($15) and do a little modification to it. and then Your system will sound as good orbetter then factory BOSE set up
Old Apr 27, 2007 | 8:33 AM
jazzson007's Avatar
What would the non XMIPOD harness do? What do you mean by modify it?
Old Apr 27, 2007 | 1:22 PM
gm_geek's Avatar
modifying that harness You can seamlessly integrateplug and play solution to add ahtermarket amp to your Nav Radio
Old Jul 12, 2007 | 8:53 PM
SENECA's Avatar
Any schematics on how this can be done?
cmonteiro1
Jan 8, 2009 9:32 PM
bignatewilson
Sep 4, 2008 11:48 PM
biglg
Jan 22, 2008 8:16 PM
kbeas
May 26, 2007 9:40 AM
