Chevrolet Avalanche
Platform: GMT 805 & 900
2007 chevy avalanche 4x4 axle questions
Old Sep 1, 2009 | 10:22 PM
tatt2kid's Avatar
Default 2007 chevy avalanche 4x4 axle questions
on rear axle should i remove the cover or just suck out used gear oil thru the fill hole and refill with fresh fluid? i know front axle is easy going drain refill...i have 62,000 on the truck.
Old Sep 2, 2009 | 11:08 AM
myotherchevyisablazer's Avatar
just mt opinion,but i would remove the cover when changing the gear oil.That way you can do an inspection to make sure all is good(no loose parts floating around)if you were to pull out the fluid there is a chance all will not come out...after you change it out run a bead of sealant around the housing slap the cover on a fill....good luck
and welcome, hang around awhile
Old Sep 2, 2009 | 7:16 PM
tatt2kid's Avatar
oh ok thanks for the feed back went to dealer today and picked up gasket for the axle..As well as Transfer case fluid so i can change that out to.thats just a drain and fill..drain plug fill plug love that
mcphck
Aug 21, 2012 5:37 PM
stevesobel24
Dec 2, 2011 1:10 PM
camaro84
Mar 12, 2009 8:05 AM
jpbjr1955
Nov 10, 2008 2:59 PM
badaz06
Avalanche
Apr 29, 2008 12:36 AM
