Chevrolet Avalanche
Platform: GMT 805 & 900
brake issues 2004 avalanche
Old Dec 7, 2011 | 5:29 AM
curtisj8's Avatar
Question brake issues 2004 avalanche
just bought a 2004 chev avalanche about 2 months ago. since ive bought it ive been having the brake at random time engaging. its not sticky calipers because one ive checked them and 2 its not from dead stop. has no real consistent time it happens. phoned around and they tell me its the abs sensors and other them me that isnt possible. anyways long story short im lost and its really kicken the crap out of the truck.
Old Dec 11, 2011 | 4:25 PM
avgas's Avatar
If you are talking about the brakes feeling funny when you are applying the brake it could be the antilock brake system activating. I have seen this happen when one of the front abs sensors was not working correctly. The front wheel bearings were replaced and the hubs came with new abs sensors in them. The sensor on one of the hubs was not seated properly so when turning and applying the brake the abs system would engage. I would start looking at the abs sensors.
Old Dec 13, 2011 | 2:13 AM
curtisj8's Avatar
thanks "avgas" thats a start anyways i guess. its not really that my brakes feel funny but more they are all coming on just drivin down the road. ill take a closer look around the sensors this weekend when i get a minute. is there anyway to test each sensor?
Old Dec 13, 2011 | 7:33 PM
avgas's Avatar
I am not sure how you would test each sensor. If your saying the brakes are applied without your foot being on the brake pedal you have a anti-lock brake issue. The anti-lock brake system has a electric motor / pump that produces brake pressure. That would be the only way any brake fluid could be forced into the braking system.
Old Dec 13, 2011 | 7:46 PM
Drew82's Avatar
Do you have a "Brake Team" in your area? They would prob be able to test each for you for free or cheap...
Old Dec 14, 2011 | 2:26 AM
curtisj8's Avatar
not that i know of. i got a few people around her puzzled. the chev dealers around here (pei, canada) havent really been much of a help. i have one main guy i stick to for all this kind of work. he told me to pull the abs fuse the other morn so i did that so wait and see. to be 100% honest i dont have a clue about abs other then i know its purpose and its near caused a few smashed cars of mine. if its a matter of livin with a light on the dash im fine with that but would be nice to get it fixed.
thanks again for the help guys
Old Dec 16, 2011 | 5:06 AM
curtisj8's Avatar
so hers the issue. unplugged the abs fuse from under the hood. brake still coming on for no reason while drivin down the road. so that should scratch the abs from the list of possible issues right? what now?
Old Dec 16, 2011 | 9:39 AM
curtisj8's Avatar
seem to be more the drivers side on the front the any other tire. well hot to touch anyways
Old Dec 17, 2011 | 2:56 PM
curtisj8's Avatar
ok so heres the latest. went to change the front brake pads. when i went to compress the caliber it wouldnt move at all. not even enough to be able to remove it. i had to release the pressure from the bleeder screw. so is that a slave cylinder issue or something else. would it be possible that would be my problem all along. would thought cause the rest to slowly come on some how
Old Dec 17, 2011 | 4:56 PM
EinST's Avatar
It sounds like a sticking isolation valve (part of the BPMV) which is normally open when the ABS is not active. Consider taking it in for service. You need a scan tool to diagnose the 2004 properly. I've been told that especially the BPMV is nothing to fool with.
