Chevrolet Avalanche
Platform: GMT 805 & 900
A/C recharge
Old Jul 6, 2021 | 3:33 PM
Kalel51965's Avatar
Default A/C recharge
I am trying to recharge the air conditioning on my 2010 Chevy Avalanche LTZ and I have run into a problem. What I think is the low pressure port, I can’t get the quick release on the Freon can to connect. The only other port is attached to the evaporator. Can someone help me identify wher the low pressure port is? I have attached a picture of the compressor lines. Or do I need a special connector?
Which cap is low pressure?
Old Jul 6, 2021 | 3:52 PM
kevinkpk's Avatar
Low port is the larger schrader valve.
Old Jul 6, 2021 | 7:55 PM
low port is on the accumulator...the port with green dye on it.
you can"t see the evaporator...its in the hvac case in the passenger compartment
Old Jul 6, 2021 | 8:40 PM
Kalel51965's Avatar
Thank you so much
Old Jul 9, 2021 | 11:12 PM
wash the dye off when you are done. if it goes green after washing...you have found the leak point.
tagrahamta
2014 - 2018 (GMT-K2)
Mar 11, 2021 8:48 PM
RNGR Q
Jun 30, 2014 7:54 PM
w002mia
Mar 27, 2013 10:28 PM
Arizona
Jun 8, 2012 4:15 AM
mj58595
Oct 7, 2006 1:03 PM
