Chevrolet Avalanche
Platform: GMT 805 & 900
Coolant system issues
Old Oct 4, 2023 | 6:19 PM
MKnice12's Avatar
Default Coolant system issues
I think my 2002 Avalanche Z66 is burning a little coolant. The last couple days my low coolant light came on. I noticed a puddle of coolant under the truck. It is coming out of the overflow after I turn off the engine. In the morning the coolant is a little low in the overflow container.
The engine temp while running is close to 200 degrees. the oil is clear.
Does anyone know what might be causing this?
Old Oct 4, 2023 | 6:27 PM
make sure the pressure cap is on all the way, or replace it. It could be worn out.
Old Oct 4, 2023 | 7:22 PM
MKnice12's Avatar
What are you referring to as pressure cap?
Old Oct 4, 2023 | 7:40 PM
the cap that holds pressure inside the cooling system .Yours is probably on the radiator.
andrewsavalanche02
Avalanche
Sep 29, 2021 9:54 AM
gschroeder
Jul 13, 2013 1:12 PM
Bbell
Feb 5, 2013 8:28 PM
mattrules
Mar 24, 2011 12:32 PM
angieman
Oct 19, 2006 12:00 AM
