Chevrolet Avalanche
Platform: GMT 805 & 900
Midgate Crossbar Question
Old Apr 22, 2011 | 4:11 PM
Inertiatic's Avatar
Default Midgate Crossbar Question
I recently bought a 2003 Chevy Avalanche from a private seller. Since buying, I've found a few problems.
My main concern is the midgate crossbar. I can remove the window, and lower the bottom section of the midgate. My problem is this: when I try to lower both the midgate and the crossbar, it doesn't release. Because of this - I can't have the midgate fully 'open' like it should be. I have to settle for having a bar between the open space, which I don't like.
I've managed to remove the midgate crossbar by itself, but I can't figure out how to take it apart (the plastic cover won't come off without removing the handle - which I don't know how to remove). I had to pry the plastic trim cover back just enough to push the release mechanism to be able to pull it out.
It seems like the handle just doesn't 'grab' when I twist it. I can feel it release when lowering the bottom of the midgate, but when I twist it to lower the entire section, it turns without any resistance.
Please help.
Old Apr 28, 2011 | 8:23 PM
Tyger's Avatar
Take it to a dealer. They'll be able to determine which is faulty, the gun or the gunner. If it's the gunner they'll show you how to remove it.
pcm2a
Avalanche
Mar 15, 2011 5:42 PM
JTS51
Feb 22, 2011 8:42 PM
Recceman
May 2, 2009 8:54 AM
Helliex
Feb 1, 2009 10:57 PM
nfruge56
Dec 6, 2006 1:31 AM
