Chevrolet Avalanche
Platform: GMT 805 & 900
problems on right side of Avalanche
Old Aug 8, 2020 | 12:35 AM
lmnior204's Avatar
Default problems on right side of Avalanche
My passenger side window mirror all stopped working anyone know the problem 2003 Avalanche?
Old Aug 8, 2020 | 7:56 PM
some options are:
broken wires in the door A-pillar
bad master switch
bad mirror motor
to figure out which one:
remove the passenger door trim panel, unplug the mirror connector and check for power to the connector when the switch is pressed. if power and grd are present the probem is in the mirror itself...replace it
if no power....check for power out of the switch...if ok, the wiring is broken...check in the rubber loom at the door A-pillar
Old Aug 9, 2020 | 12:32 PM
Jimknighter's Avatar
Default Mirrors don't work
The plastic gears are prone to crack and fail. You can buy brass replacements online and fix yourself if that's the problem.
Jim
Svanbru1
Avalanche
May 27, 2020 8:39 PM
Johnny Mayday
Avalanche
Oct 3, 2017 9:10 AM
Avykid
Avalanche
Jul 24, 2017 12:54 AM
03avy
Avalanche
Jul 12, 2011 10:42 PM
ohfive
Avalanche
Aug 18, 2008 10:41 PM
