Chevrolet Avalanche
Platform: GMT 805 & 900
Setting tpms
Old Jul 29, 2021 | 2:07 AM
Tomas's Avatar
Default Setting tpms
Hi
I have a 2011 Avalanche and I need to set the Tire pressure system. The only way to activate learning mode is to switch on ignition and the press lock/unlock buttons. Then the system activates learning mode and front legat and rear left turn signals lit up. I scan the left front tire and the the horn beeps and right front and right rear signals lit up, then I scan right front tire and the horn beeps. After this no turn signals lit up and I cant scan the rear tire. What can cause this problem?
Old Jul 29, 2021 | 5:26 PM
2001 chevy silverado's Avatar
either the instructions you got are wrong (thus the test mode ends before you get to the last tire) OR - that sensor is bad
TPS sensors do go bad frequently. I think you cannot replace them with a normal stem since the hole is machined different. You can take the bulb out of the TPS warning so it's not annoyingly flashing all the time, though.
Old Jul 29, 2021 | 7:54 PM
the batteries in the sensors do have a lifetime....and eleven years is probably past it. any sensor that will not register needs replacement.
Do not remove the bulb from your cluster...in the states its a federally mandated system. My thinking is It will need to do a bulb check to pass safety inspection.
Old Jul 31, 2021 | 5:46 PM
Tomas's Avatar
Default Thanks
Thanks a lot for your anser. Problem solved since one sensor was brooken. Now the broken sensor is replaced and everything is working fine.
Frugal Dave
14
May 22, 2020 11:52 AM
CoachVince
May 6, 2014 2:56 PM
martin18152
Mar 3, 2014 12:08 PM
fe_pony
Mar 22, 2008 7:33 PM
tahoe07
Dec 11, 2006 8:16 PM
