Chevrolet Avalanche
Platform: GMT 805 & 900
Transmission Late Shifting
Old Dec 20, 2015 | 10:10 AM
dobaroy's Avatar
Default Transmission Late Shifting
On our 04 Avalanche the trans is very late shifting, at about 4,000 rpm, unless you let off the gas and then reapply gas. Could it be possible that this is caused by a corroded ground strap from the body to the transmission?
Thanks, look forward to hearing your thoughts on this.
Old Dec 20, 2015 | 10:31 AM
chevy55's Avatar
is it lacking power when this happens,i have experienced this before and it was a friends tahoe which had a plugged caytaletic convertor.his truck would rev high and as you said let off the gas and reapply and it would shift.when the cats start to plug it can cause long and delayed shifting and lack of power.
Old Dec 21, 2015 | 7:04 AM
dobaroy's Avatar
Thanks chevy55, will check to see what shape the cat is in. Appreciate your suggestion.
Old Dec 22, 2015 | 10:51 PM
cleveland63b's Avatar
trans fluid full? smell or look burnt or dark?
Old Dec 23, 2015 | 6:04 PM
dobaroy's Avatar
Thanks Cleveland, trans is full and fluid is real red and does not smell burnt.
what does 63b mean? ? ?
Old Dec 23, 2015 | 11:59 PM
it used to be a mos/job when I was in the army
Old Dec 24, 2015 | 7:30 AM
dobaroy's Avatar
Thanks, thought maybe it was a '63 car you had.
