Chevrolet Avalanche
Platform: GMT 805 & 900
Turn Signals are not working correctly
Old Apr 8, 2014 | 11:30 AM
P-Liddy's Avatar
Default Turn Signals are not working correctly
My right turn signal works correctly but when I switch it back to the "off" position in still stays on. The left turn signal doesn't turn on when I try and turn it on. I have to drive with it on the left turn position just to stop the signal lights. Not sure where to even begin. Please help if you can.
Old Apr 8, 2014 | 12:04 PM
Sounds like the turn signal switch is bad. You will most likely have to remove the steering wheel to make repairs. What year and vehicle do you have?
Old Apr 8, 2014 | 2:20 PM
P-Liddy's Avatar
2007 Avalanche.
Thanks, that's a start for me to look at, at least.
Old Apr 9, 2014 | 8:39 PM
sledge.impy's Avatar
Originally Posted by P-Liddy
2007 Avalanche.
Is there a halfway position that turns it on where you hold it manually? will it turn off when your release back to neutral?
Old Apr 27, 2014 | 12:07 AM
thzpcs's Avatar
What happens when you use the emergency flashers?
Mandi0175
Jan 29, 2022 7:29 AM
Factory909
Jun 23, 2014 2:39 PM
donjuandejohnson
Mar 18, 2009 1:30 PM
Manor_Mullet
Apr 28, 2008 2:13 PM
ScootersLTZ
Apr 11, 2007 1:01 PM
