When 4wd is engaged the front end lifts up, when I back up it goes back down.
I recently purchased an 2004 chevy Avalanche. I replace all the front suspension parts as they all were wore out. It is 4wd with autotrac system. The previous owner had removed the front drive shaft due the bracket that holds the differential in place had broke. I had this bracket replaced and replaced the front driveshaft. After all parts had been installed when I drive forward and the front end raises up and makes binding noises. When I back up the front end goes back down to normal. Has anyone ever seen this before or have any suggestions I could try?
