Chevrolet Avalanche
Platform: GMT 805 & 900
Whine in front end of Avalanche
Old February 28th, 2012 | 2:46 PM
thomss64's Avatar
Exclamation Whine in front end of Avalanche
I have a whine in the front end when making a sharp right turn on my 2006 Avalanche . Very pronounced at first but then diminishes a little for a while.
It seems to do this when it (the engine )is cold. I just noticed this happening a couple of weeks a go (66,000 mile ) . I thought of a wheel bearing, but checked and that is not the issue. Open to suggestions
Old February 29th, 2012 | 8:22 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> thomss64,
The power steering pump may be a possibility. This is merely a suggestion, not a diagnosis. I encourage you to have the vehicle inspected by a certified technician, they will be able to offer a more accurate diagnosis after a physical inspection.
Please keep us posted.
Louis
GM Customer Service
Old February 29th, 2012 | 9:27 PM
cleveland63b's Avatar
does it only happen when you do right turns or left also?
randyehughes
September 29th, 2019 10:58 PM
brewmaster
February 22nd, 2013 3:57 PM
makeitright
14
December 18th, 2011 10:46 PM
mercracing
September 20th, 2011 2:03 PM
randyehughes
June 7th, 2006 6:56 PM
