Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1996 Corsica temp Gauge
Old Nov 29, 2014 | 10:08 PM
Railroadertwo's Avatar
Default 1996 Corsica temp Gauge
I have a 1996 Chevy Corsica 3.1, and the temp gauge is not working, it was until I changed the upper and lower intake manifold gaskets, the Coolant temp sensor is new, the cooling fan works as it should. I checked the wiring from the sensor to the harness connection near the alternator, all three wires had continuity. I am out of ideas. Thanks
Old Dec 14, 2014 | 7:33 PM
sledge.impy's Avatar
Do you have the old sensor? Why did you replace it?
Anyways - unplug the new sensor, plug in the old one. (Don't install). Does it work? You might to dip the old sensor in some hot boiling water I guess to get a reading.
Well, that's just an odd idea I had.
Old Dec 15, 2014 | 11:41 AM
I ordered and received two factory service manuals off of ebay, using the test procedure outlined in the manual, gauge tested OK, appears to be a bad connector and or wiring problem, I may have damaged something when I removed the plenum, and yes I connected the old sensor, no joy, so, I am going to get a new connector and run new wires to the harness connector near the alternator. Thank you for your reply.
Old May 9, 2015 | 1:49 PM
Problem Solved, broken wire coming from the sensor, also the sensor was defective.
flat350
Mar 6, 2011 12:32 PM
Mauler
Mar 2, 2009 6:40 PM
jcubmsp
Feb 11, 2009 6:07 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
