Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
92 corsica question
Old Oct 14, 2012 | 5:45 PM
92chevycorsicalt's Avatar
Default 92 corsica question
I have a 92 Corsica 3.1 auto the motor is shot I have a 96 Corsica that's wrecked can I put the 96 motor in my 92 and if so what all will I need to swap?
Old Oct 14, 2012 | 6:02 PM
kevinkpk's Avatar
I think so as long as it is the same 3.1 else your looking at possible reflashing the ecm.
Old Oct 16, 2012 | 8:19 AM
There both 3100 motors but the Vin codes are different
Old Oct 27, 2012 | 1:21 PM
GHOSTOWLGRID's Avatar
The 92 Corsica engine should be this:
Google Image Result for http://static.cargurus.com/images/site/2009/08/16/14/42/1991_chevrolet_corsica_4_dr_lt_sedan-pic-4292.jpeg
The 96 Corsica engine should be this:
Google Image Result for http://images.gtcarlot.com/pictures/38245759.jpg
This is as far as them being both a v6.
The engine mounts will most likely be different.
The wiring will for sure be different
The old ECM and wiring will run the 96 SFI v6 engine design, but I can't say if it will be smooth or fuel efficient, it will run it like the did the old 3.1 design. MPFI. not SFI.
You can keep the same transmission, or take the newer trans with the SFI engine.
If you also use the 96 trans, it will mean the wiring harness as well and the ECM with that engine/trans design. Its more fuel efficient that way, the old ECM wont run the 96 trans.
Newer 3.1 SFI v6 on the 92 trans will mean properly mounting the kick back cable on the 96 throttle body linkage. Which can be done, However I never have. I used my old 3.1 throttle body on the 3100 SFI engine because it was easier. I just removed the vacuum line ports and put a flat plate over them to seal them...
It is your choice, I can help you the best I can, just ask.
*I have done this before with my Beretta's.
Rmbb
Mar 25, 2014 3:37 AM
oilyhands
Mar 23, 2008 6:45 AM
epekarik
Jul 14, 2006 12:51 AM
Johan
Jun 29, 2006 2:20 PM
showin57
Mar 13, 2005 1:36 PM
