Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
95 Corsica Engine Stumble/Chug
Old Nov 14, 2006 | 11:34 PM
raysrestoration's Avatar
Default 95 Corsica Engine Stumble/Chug
95 Corsica 2.2 4 cyl currently at 218,000K
Car details from ad online, bought in sept at 211K and
been driving >1000 K a week since.
New exhaust (catyletic converter, muffler, etc.) New
oxygen sensor, new spark plugs, new spark plug wires, new pcv valve, new thermostat, new serpentine belt, new head gasket, new battery, new alternator, new starter, new brakes, new calipers, New Suspension (front struts and strut mounts and rear shocks and shock mounts) New wheel bearing, New tie rod end, new ball joint, K & N Air filter.
Fluids are good, oil was burning in frequent aggressive
highway passing - approximately 1 litre of oil per 200 K. Oil last's 10 times longer since adding 250 mil of
Rislone Oil Treatment.
Question 1 - Engine Stumble
The car runs well and gets decent mileage, tends to idle
a little rough at times - engine tremble/bogging. At a
constant speed between 60 - 90 Kph the car stumbles,
never dies and can be remedied by accelerating as driving at 100 or greater does not seem to have any problems and the car rides smooth.
-K&N Air Filter seems a little oily, there was oil and
sweat inside the air filter compartment.
-Throttle Body had black tar around throttle plate, tried to clean it with throttle body cleaner - still dirty past the plate into the two tubes inside the housing.
Not sure what next to rule out, I hope to do a compresion test to see if it is rings are worn.
Can send pictures via email if it helps figuring it out.
Thanks
rayandjenny@rogers.com
Old Nov 16, 2006 | 1:07 PM
uncle bill's Avatar
Default RE: 95 Corsica Engine Stumble/Chug
I've had pretty good luck with high mileage vahicles using CHEVRON Techron as a Fuel injection / valve cleaner. Just pisk some up and add it to the fuel for a few tankfulls. The stuff is amazing for high miles.
Old Dec 30, 2006 | 8:58 PM
Thanks for the tip, turned out to be poorly seated spark plugs. I was pretty shocked to see that the #4 plug was only half threaded. Ended up re tapping the hole with a grinded used plug.
Thanks
Ray
wilke_jb
Dec 13, 2008 9:23 AM
L507809
Feb 10, 2008 6:01 PM
03blackburb
Corvette
Sep 20, 2007 10:51 PM
daemon
Feb 22, 2006 9:20 PM
