Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
98 Chevy Lumina LTZ 3.8L, Stalling and MAFS probs
Old Aug 16, 2006 | 6:58 PM
bjthebetsig's Avatar
Default 98 Chevy Lumina LTZ 3.8L, Stalling and MAFS probs
Hey,
I am working on my buddies car as described as above. Here's the symptoms:
1) The car will turn over and fire, and for the most part idle. Sometimes the car will die immediately after starting, sometimes not. This problem is getting worse and worse
2)At 4000 RPM the engine will chug. This happens in all scenarios (Park, neutral, drive).
3)At sparatic points, usually at low RPM's, the car will stall while driving.
4)NAPA code checked the engine and reported a problem at the MAF sensor (mass air flow).
This started happening less than a month ago, and has been deteriorating quickly. We replaced the fuel filter thinking not enough fuel was reaching the engine. This did not effect the situation at all. The car has 106K on it. We took out the sensor and it looks fine (no dirt, contacts still shined, the resistor looked fine). We have a new sensor on order with NAPA that we are getting by friday, but we have an inkling that's not the problem. Aside from oil, no tuneups have been done to the engine, not even spark plugs.
The main question of this thread: Is there anything else that could be causing the symptoms?
Old Aug 25, 2006 | 11:33 AM
tidahe's Avatar
Default RE: 98 Chevy Lumina LTZ 3.8L, Stalling and MAFS probs
I've got a '90 Lumina with the same problem (cutting out at around 4,000 rpms and stalling when driving) exept it's got the 3.1L engine rather than the 3.8. The check engine light has not come on and my Snap-On scanner didn't come up with anything. The rpms go way up and way down and eventually it stalls. It starts right back up but then goes back to the same symptoms. Any suggestions?
Old Aug 25, 2006 | 6:44 PM
kcb37's Avatar
I would wait it out and see what the maf sensor does.
Old Aug 26, 2006 | 12:24 PM
tidahe's Avatar
Works for me. Thanks.
Danman2897
Nov 1, 2012 4:26 PM
Danman2897
Oct 31, 2012 9:37 PM
reedb
Camaro
Jun 24, 2012 1:21 PM
lovesmonica
Mar 22, 2011 8:02 PM
kidm28
Oct 18, 2006 12:28 AM
