Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
DTC 64 MAP Sensor Circuit Voltage Low
Old May 27, 2010 | 10:46 AM
USR_BS's Avatar
Default DTC 64 MAP Sensor Circuit Voltage Low
Hi Everyone! I'm a newbie to this forum as well to Corsica's. I recently picked up a 1988 Corsica for a commuter that im trying to get to pass smog. Im having trouble with a DTC code 64. My programmer says its a MAP sensor circuit signal voltage low. From what Ive been reading low voltage= low pressure= high vacuum??? Any help to kill this fault code from popping up so i can pass smog would be great! The only symptoms the car is showing is a bit of a low idle and a very small hesitation on initial acceleration.
I found cracked vacuum hoses going to the MAP sensor as well as replaced the sensor with a brand new one. And unfortunately the code keeps popping up after I reset it. Any other suggestions???
Thanks for your help in advance!
Regards
wolfdogg
Sep 3, 2012 2:06 PM
scrnchr
Jan 26, 2012 10:43 AM
ldearman
May 5, 2011 4:08 PM
williamvaldivia
Mar 19, 2009 11:03 PM
