Oil spewing from oil filler tube 95 corsical 2.2
My corsica has been running great for a while but i noticed the other day it was smoking under the hood, while not being overheated. I poped my hood and noticed a large amount of oil had spewed from the under the dipstick cap all over the engine. What can be the cause?
The car is missing at low RPMs, and has smoke coming out from the dipstick tube if i take the dipstick out, once i get going in the car, around 20mph the car runs fine.
What should i check first?
What you describe is high crankcase pressure. I'd suggest make sure the pcv valve is working. With engine running, pull the valve with the hose hooked to it, place your thumb on the engine side, does it stop?
mattintc
Sep 18, 2012 10:56 AM
