Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Oil spewing from oil filler tube 95 corsical 2.2
Old Aug 25, 2012 | 2:19 PM
IhateMyCorsica's Avatar
Default Oil spewing from oil filler tube 95 corsical 2.2
My corsica has been running great for a while but i noticed the other day it was smoking under the hood, while not being overheated. I poped my hood and noticed a large amount of oil had spewed from the under the dipstick cap all over the engine. What can be the cause?
The car is missing at low RPMs, and has smoke coming out from the dipstick tube if i take the dipstick out, once i get going in the car, around 20mph the car runs fine.
What should i check first?
Old Aug 25, 2012 | 2:44 PM
kevinkpk's Avatar
I'd suggest changing the PCV valve
Old Aug 25, 2012 | 4:33 PM
i checked the pcv valve, it's still rattling, that means its still good right? should i change it anyways?
Old Aug 25, 2012 | 4:58 PM
kevinkpk's Avatar
What you describe is high crankcase pressure. I'd suggest make sure the pcv valve is working. With engine running, pull the valve with the hose hooked to it, place your thumb on the engine side, does it stop?
Old Oct 27, 2012 | 3:06 PM
GHOSTOWLGRID's Avatar
Something might be wrong with one of the pistons/rings...
or a bad head gasket... or bad heads...
Sparky Sparks
Dec 4, 2020 10:58 PM
mattintc
Sep 18, 2012 10:56 AM
Prismatic
Jun 15, 2012 12:02 AM
mob_boss251
Colorado
Mar 3, 2009 6:05 PM
sixpack_sid
Nov 14, 2008 11:21 AM
