Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Replacing the radiator on a 1996 2.2L Corsica. Some help please.
Old Jun 26, 2016 | 6:52 PM
wnlewis's Avatar
Default Replacing the radiator on a 1996 2.2L Corsica. Some help please.
I am replacing the radiator on my wife's 2.2L Corsica.
I got the radiator out and have the new one waiting to go in.
However, I am not quite certain what the following items are - the information comes from 1996 L Platform GMP/96-L-1 Book 1 of 2 for the Corsica/Beretta (shop manual):
Page 6B-16, Radiator Remove or Disconnect,
• Step 3, "Air intake duct assembly". What is it? I believe it is that part that is integral with the battery holder, which if removed makes it a whole lot easier to remove the radiator - but I do not know that for certain. Is there any place in the shop manual that identifies that item - hopefully with a picture.
• Step 9. "Splash guard below lower radiator hose". What is it and why do I need to remove it?
There is a gray rubber molded strip that came off from somewhere. Where does it go and what is it?
I can send a picture of it.
Also, the air conditioner (A/C) condenser is bent in an asymetrical curve from side to side. I don't that that is normal. My inclination is to replace it.
Thanks for your help.
wnlewis
Old Jun 28, 2016 | 7:31 PM
wnlewis's Avatar
Default Photos of the rubber strip
Here are three photos of the rubber strip that came out when I was removing the radiator. It was on the ground when I first saw it. I did not see where it attached. wnlewis
