Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Soft brake pedal at start up
Old Apr 13, 2013 | 9:33 PM
Blue92's Avatar
Default Soft brake pedal at start up
I recently replaced the rear brakes on my '92 Corsica. I bled the brakes the same day. Since then, I've noticed that the brake pedal is soft/spongey when I go to shift from Park to Reverse/Drive. After I start driving, the brake pedal gets firm. The level of brake fluid in the reservior has stayed the same. I'm just curious what might be causing this. Any ideas?
Old Jun 15, 2013 | 11:48 AM
GHOSTOWLGRID's Avatar
Sounds like air in the break lines.
How did you bleed them?
It is a 2 person process.
"Open, then push peddle, then close, then release peddle, check fluid level after 2-3 times."
Also, My car had a failed master break cylinder, it would not push any fluid through, kinda acted like spongy breaks, but defiantly would not stop the car.
But it does not sound like yours. The way to tell is when bleeding the breaks, does fluid squire out with force?
97RedBull
16
Jan 12, 2022 1:37 PM
next2nothing000
Oct 10, 2021 9:25 AM
hopakco
18
Jan 8, 2020 6:32 PM
oldtruckgoodtruck
Aug 21, 2016 9:04 PM
69rrvert
Oct 22, 2009 4:59 PM
