Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Took a picture/AIR CHARGE TEMP sensor.....
Old Jun 26, 2008 | 5:34 PM
ss66's Avatar
Default Took a picture/AIR CHARGE TEMP sensor.....
Is THIS the AIR CHARGE TEMPERATURE sensor (3.1 liter)? EDIT( I now think this is the MAP sensor ).. where is the AIR CHARGE TEMP SENSOR?! )
The car has been driving me nuts. First start of the day it fires right up and drives fine till I park it. When I go to leave it starts OK but dies when going into drive unless I give it a good amount of gas. And will keep dying the entire ride home if I let it drop near idle speeds. This is NOT the torque converters solenoid. The only code I get is a 23 which is AIR CHARGE TEMP SENSOR. Do you guys think this sounds like it would cause this problem? Would a bad ignition control module throw the computer a code? I suspect it may be the module because from what I read they can act up when warm...any other suggestions? Remember, it only seems to do it after it gets hot.. grrrr
Old Jun 26, 2008 | 9:29 PM
EvansBlue's Avatar
Default RE: Took a picture/AIR CHARGE TEMP sensor.....
Most of the time, IAT sensorss (ACTS) are not that elaborate. Look for it further down the intake tube toward the filter.
Old Jun 26, 2008 | 10:07 PM
ss66's Avatar
There is nothing else between there and the Air filter. Just the sensor ON the air filter box...
Im suspecting my problem is also being caused by a bad coolant temp sensor. My coolant temp light NEVER goes off.. even though the car isnt throwing a code for it...
Do you happen to know where this is located? thanks
Old Jun 27, 2008 | 9:17 AM
EvansBlue's Avatar
Thats located right above themiddle of the exhaust mainifold typically. The part is called "temperature sender".[/align]
Old Jun 27, 2008 | 1:16 PM
ss66's Avatar
ORIGINAL: EuroGoldLS
Thanks
Old Jun 27, 2008 | 2:46 PM
EvansBlue's Avatar
You found it?
Old Jun 27, 2008 | 3:45 PM
ss66's Avatar
EDIT: I found the sensor, turns out its the one on the air cleaner. Advance auto parts has two listed though, an air cleaner one and one that threads to the engine somewhere. That confused the hell out of me!
I took the coolant temp sensor off too... my temp gauge works fine but my coolant temperature light is ALWAYS on.. do you think I should replace the sensor? Im pretty sure this car just has a single unit. Not a sensor AND a sender... I would think its fine though since its giving me a temperature. And I know its accurate because once it hits the temp the thermostat should open at it begins to drop.
You found it?
skategranger
Feb 18, 2013 2:38 PM
Trista1985
Feb 18, 2011 3:38 AM
MalibuMaxxSS
May 16, 2008 11:40 AM
smitty
Jan 8, 2008 12:32 PM
duedja
Aug 14, 2007 4:20 PM
