4wd not kicking in to 2wd
I have a 1999 Chevy Blazer 4wd 2 door.
It will not kick from 4wd into 2wd. I replaced Transfer case control module,and Acuator in it. I hear a grinding noise when putting from 4wd to 2wd. Any ideas of what is going on?
Which actuator did you replace - the one on the front axle or the encoder motor on the transfer case?
Have you checked the fluid level & condition in the transfer case?
DianaT
November 29th, 2007 12:12 AM
