2016 Camaro
Platform: F-Body & Zeta.
2000 camaro
Old Jul 16, 2012 | 2:29 PM
Atwiss's Avatar
Default 2000 camaro
hey everyone I just bought a 2000 camaro z28 and im having a problem with it. My high beams dont work, the cruise control won't work and when I turn my blinker on it won't **** itself off when I make a left turn any ideas?
Old Jul 16, 2012 | 3:30 PM
kevinkpk's Avatar
They are all related to the turn signal switch in the column.
Old Jul 16, 2012 | 4:51 PM
Atwiss's Avatar
What all years are compatible?
Old Jul 17, 2012 | 2:32 PM
Atwiss's Avatar
Also this one is starting to tick me off.today it started to squeal constantly,i cant really tell where its coming from but I was looking at it and my main pulley has a slight wobble to it. Could that be the cause and how would I fix it
Old Jul 19, 2012 | 7:07 AM
Jeff Collision's Avatar
Check your bulbs and headlamp fuses are under the hood in electric box, and also check you wiring which is closest to the bulb/connector.
Old Jul 25, 2012 | 4:31 AM
Atwiss's Avatar
I got the squeal fixed and my cruise control fixed, I checked my bulbs fuses and wiring and everything is good but they won't switch off the high beams and I read something about a rod going down the steering column that could be bent? And this just started but its really embarrassing but when I turn the key over it won't start unless I mess with the steering wheel any ideas?
70ssrag
Dec 25, 2006 9:47 PM
sdizzlepimp
Camaro
Dec 24, 2006 8:09 PM
busyba
Camaro
Feb 21, 2006 4:30 PM
