2016 Camaro
Platform: F-Body & Zeta.
2010 Chevy Camaro Window and Door Issue
Old Jan 30, 2017 | 3:18 AM
stoutbabe1's Avatar
Default 2010 Chevy Camaro Window and Door Issue
So I have a 2010 Camaro V6 3.6L LT model and my driver's side window will roll down about an inch when the door is opened and does not roll up when it's shut. When I get back in the car, on the DIC it tells me to roll down the window and roll it up and after I do that, it works for the time I'm in the car. I did the resetting of undoing the door sensor and it worked for a little bit and then it failed again. Then I tried the removing of fuse 26 and again it worked for a little bit and did it again. Now it's starting to not register that the door is closed when it is completely latched. Are these issues related and if so, what could it be caused from? I read actuator but I didn't know if it was something else. Thanks in advance!!
Old Jan 31, 2017 | 7:21 AM
Welcome to the forum.
Not familiar with the new Camaros but it sounds like a sensor is going Tango Uniform.
