2016 Camaro
Platform: F-Body & Zeta.
327 oil leak, can’t find!
Old Sep 17, 2021 | 5:34 AM
Hudson10's Avatar
Default 327 oil leak, can’t find!
I purchased a 68 camaro with the original 327. Previous owner said it had a small oil leak after running. I assumed it would be the rear main but after further inspection the oil actually comes down the firewall above the transmission and drips down onto the exhaust. I also found it comes down the block to the oil filter on drivers side and passenger side to starter. It is enough that it’s even in the flywheel dust cover. I pulled that off and cleaned it, including spraying underside with brake clean then added dye to the oil. Tonight I found a little oil at the back of intake manifold but no other obvious place it was coming from so I started it up. Once warm I could smell the oil burning on the exhaust meaning it’s running down above the transmission again but I could not find any oil coming from the back of the block with a black light and mirror. It is tight back there but I feel I did a descent job of looking.
Where can the oil be coming from that it would run down the block above the bell housing and also run down the body under the doors and onto the exhaust? It would have to be spraying for that to happen right?
regards
Hudson10
https://192168101.link/
Old Sep 17, 2021 | 7:14 AM
kevinkpk's Avatar
Check valve cover gaskets.
Old Sep 17, 2021 | 7:32 AM
hanky's Avatar
A little trick those of us in the trade use is to clean the area and spray a little talcum powder around it and observe where the leak is originating.
Works for various leaks that are difficult to pin down.
Alex Recupero
Aug 19, 2021 11:37 AM
Typerod
Jan 5, 2019 4:14 PM
Twscarp
Jun 12, 2017 7:56 AM
jstatham
Dec 4, 2013 8:56 AM
Sean1021
Aug 14, 2012 5:32 PM
