2016 Camaro
Platform: F-Body & Zeta.
69 Camaro 400 sbs no spark
Old Oct 4, 2013 | 5:09 PM
BigBlueHoe's Avatar
Default 69 Camaro 400 sbc no spark
i have a 69 camaro with a 400 and it gets no spark. i just put in a new ignition coil and still nothing. its been sitting for a few years, it cranks and gets fuel, just no spark. anybody know what it could be?
Old Oct 4, 2013 | 11:21 PM
old dog's Avatar
Default 400
what kind of ignition do you have ? point's ,hei .
Old Oct 5, 2013 | 7:18 AM
BigBlueHoe's Avatar
I have points
Old Oct 5, 2013 | 11:03 AM
old dog's Avatar
check for power at the distributer see if there is any spark at the points .could be a bad condenser .
Old Oct 5, 2013 | 5:35 PM
Camaro 69's Avatar
Site Ambassador
Make sure the points are opening and closing. Check for proper gap, .020 is good to get the engine running, but you want to set them with a dwell meter once the engine is running. I'd first start off by replacing the points and condenser though. This is assuming you're getting key on and start position power at the + terminal of the coil.
Old Dec 1, 2013 | 3:52 AM
jonmossefin's Avatar
Probably it is due to bad condenser but just to make sure why not check other areas as well. There might be some fault in there. Not sure though.
Old Dec 6, 2013 | 11:47 PM
CorvetteAndy's Avatar
Sometimes, when you want to recharge your AC, your compressor will not turn on. This is because the PCM senses low pressure and it will not let the compressor turn on.
mamulan
Aug 20, 2014 8:39 AM
stdhawaii60
Dec 24, 2010 11:14 AM
catill
Aug 30, 2010 11:07 AM
purehobby
Camaro
Aug 3, 2009 9:47 PM
