'81 Camaro steering column removal
I have an '81 Camaro and I'm changing the steering column out because the last people lost the key and broke the column. What's the best way to remove the column from the steering box? It seems to be riveted to the steering box. Before it gets to that there's a spline with teeth, shaft, and U clamp. Is it possible to take it apart there? I took the clamp off, but can't get it apart. Anybody have any good ideas? And when I finally get the column off, how hard will it be to put the new column on?
Thanks!
Thanks!
Just change the ignition lock cyl. it's much eaiser and a lot quicker. The only thing you might have to borrow is a steering wheel puller. but believe me it's the simple way out. The u-bolt on the shaft is where it splits it might be a bitch coming apart dont try to take apart the nylon washer it's ment to stay together.
JTS
JTS
slyder941
February 24th, 2016 7:22 PM
glenn irwin
October 18th, 2010 12:12 PM
DanielC409
June 16th, 2010 12:11 PM
taylorisafop
December 19th, 2008 4:57 PM
