2016 Camaro
Platform: F-Body & Zeta.
84 trans am head gasket removal?
Old Feb 6, 2012 | 12:50 PM
stanman's Avatar
Default 84 trans am head gasket removal?
My radiator is a cappuccino. Would I have to remove the engine to deal with the headgasket?
1984 305trans am
Old Feb 20, 2012 | 10:53 AM
beeguz's Avatar
No you wouldn't, need to remove the engine head gaskets are done while the engine is in the car.
It is not an easy job but it is doable, first you need to make sure it is a head gasket problem and not just a stuck thermostat causing the problem.
Remove the thermostat, and refill the radiator with water and run it a bit, if it does the same thing then look into a head gasket.
Don't leave just the water in the engine if you live in a cold area, make sure you drain it afterwards, or refill with 50/50 antifreeze.
DOBERDEWD
Dec 11, 2011 11:35 PM
Dads Toy
Oct 21, 2011 6:54 AM
gulfcoastjoe
May 4, 2008 12:38 PM
malibu_iceland
Jan 6, 2008 12:03 PM
